Heisenborg
- Dec 15, 2006
I dont recall any issues on Animal Planet or BBC's, so what would your advice be?
Interesting, thought the HD channels were DVB-S2 (MPEG4) from the start?They are in the process of doing the switchover to DVB-S2 for the HD channels
Maybe a satcr is the answer then
Yeah but i dont know which is faulty if any.
Just an update. I thought that dish alignment = signal strength and signal quality = LNB alignment. Its not the case.
I went and got a new LNB from SpaceTV, wasnt a lot so i thought why not try this, installed it and same issue, couldnt get the signal quality above 20% or so. I then tried fine adjustments to the dish and it went up to 100%. So the so called accredited installer didnt do a proper job initially. anyway sorted now, thx for the guys who advised...
