DSTV PVR REMOTE
APoc184
Tshwanetoria
I'm using a SD PVR remote for my 990 decoder and programmed it to use it with all my other electronics.
Recently got a new 42" Samsung Plasma and want to reprogram the remote to now control my new TV and not the old one.
But I cannot find the little manual with all the codes.
DSTV has it on their forum but it seems like the moderators are on leave there because they haven't activated my account for the last two days.
If anybody has this list at home please help me out with the Samsung TV codes.
SAMSUNG 42" PLASMA.
Just that code please. If it is the same as my book was, you might need to list a few of them because its not always the first one.
I think it is a 5 digit code.
Please also confirm the instructions:
You hold SHIFT for a few seconds?
Light flashes?
Then enter the code.?
Light would flash few times again if entered correctly?
Thanks Aqua
0060 Samsung T0587 T0618 T0556 T0037 T1249 T1235 T0060 T0644 T0482
T1458 T0217 T0448 T0216 T0178 T0488 T0009 T0072 T1907
T0682 T1678 T0702 T0093 T0370 T0032 T0264 T0150 T0329
T0179 T0814 T0208 T0519 T0163 T0226 T0625 T0812 T0821
5.1 Controlling TV and Audio Systems
Quick Programming Summary
Find the code for your TV.
Select mode X, Y or Z.
Press and hold SHIFT until the mode window blinks 3 times.
Enter the code.
5.1.1 What is this used for?
The PVR Remote Control has the ability to control up to three other devices apart from the PVR.
The X, Y and Z modes can each be programmed to control a TV or amplifier / home theatre
system.
Follow the instructions below and you should be able to control your entire DStv viewing
environment with just one remote control.
Note
 Only the X, Y and Z modes can be used to control other devices.
Tip
 Once you have completed programming the remote control, write the product codes on the
sticker inside the battery compartment for future reference.
5.1.2 Programming the remote to control TV / Hi-Fi devices
There are two ways to programme the remote to control other devices.
o Direct set-up : for this you need the code of your device (see the list supplied)
o Step-and-set method : the code is not required, however this method of programming the
remote control will take much longer
DStv PVR Remote Control Manual Page 10
Direct set-up
1. Find the 5-digit code for the device from the list provided in this manual (see “Code Tables”
from page 22). If there is more than one code listed for the device, start with the first one
(they are listed in order of probability).
2. Select the mode (X, Y or Z) that you would like to programme to control the other device.
3. Press and hold the SHIFT button until the mode window blinks 3 times.
4. Enter the 5-digit code using the number buttons on the remote control. (The mode window
will blink once after you enter the first 4 numbers and three times after you enter the last
number – confirming that a valid code has been received).
5. This mode can now be used to control the selected device.
Note
 The remote control will indicate an error (two slow blinks in the mode window) and exit the
programming mode if you press anything other than a number button when entering the
device code.
Step-and-set
1. Select the mode (X, Y or Z) that you would like to programme to control the other device.
2. Press and hold the SHIFT button until the mode window blinks 3 times.
3. Enter 991 using the number buttons on the remote control. (The mode window will blink
three times to indicate acceptance).
4. If you are programming the remote to control a TV, press the TV button. If you are
programming the remote to control an amplifier / home theatre system, press the ALT button.
5. Press P+ until the device you are trying to control switches on or off.
6. Press HELP to store this programme and exit the process. (The mode window will blink 3
times to indicate successful completion).
7. This mode can now be used to control the selected device.
Optional Steps
Between steps 5 and 6, you can test other functions of the device you are trying to control (instead
of the power button function). These other functions can be number buttons (0, 1, 2...) volume up,
volume down, mute, and AV. You cannot test programme up (P+) and programme down (P-).
To do this while searching, press the desired function you wish to test (eg. MUTE), and then press
P+ to continue searching. Now each time you press P+, the mute command (instead of the power
on / off command) is sent. This means you continue pressing P+ until the device goes mute
(indicating it recognises the mute command just sent).
Tip
 Once you have completed the steps above, write the programmed codes on the sticker in the
battery compartment for future reference. See “Code Verification” on page 20 if you used the
Step-and-set method to programme your device.
Note
 The P- button can be used to search backwards through the codes if the correct code was
bypassed.
 Scanning of the code database is circular. The mode window will blink 5 times on reaching
the end of the database, but it will stay in the Step-and-set programming mode and start from
the beginning of the database if P+ is pressed again.
Instructions:
-You choose x, y or z.
-Hold "shift" until 3 lights blink
-Enter 5 digit code
-3 blinks mean success
Samsung TV codes:
00049
00648
00674
00086
00090
00617
00067
00208
00060
00504
00586
00039
00732
00804
There are more codes but try those
Benq TV
Does the manual have codes for a benq TV Set, i am trying to set mine but it is taking very long to set it.
hi everyone
where can i get a dual view pvr remote control?mine fell and stoped workin
im in jhb
who's the cheapest?
Hi guys
I have problems programing my new pvr remote (model A3). (HD remote to use on SD PVR)
I followed the above thread's instructions.
I have done the following! ***The instructions are at own risk. A3 Remote***
1 = SDPVR 1
2 = SDPVR 2
3 = HDPVR
This makes sense in my household as remote environments all match up.*
Remote = TV Number (displayed on SDPVR) = Channel Number.
Method :*
Select mode 1 or 2 on the remote.
Press and hold down SHIFT key until the three blinks. Enter code 982.
This unlocks the mode and allows you to program as before.*
Select mode 1,2,A,B,3,4,C or D on the remote.
Press and hold down SHIFT key until the three blinks. Enter code xxxxx
SDPVR1 = 21589
SDPVR2 = 21590
HDPVR = 22089
I managed to program function 1 on the remote to control my PVR TV1 100%. But any other function on the remote blinks 2 red on pressing the sift key or any other keys.
Is the remote u/s or is there another code to unlock the other functions for programing.
Programmed my A3 a while ago so don't remember the exact steps. Don't recall having any issues though, only thing is to configure SDPVR not to listen to HDPVR commands.
Other difference is I didnt deviate so much from the default positions i.e. mine is setup as follows;
1 = HDPVR2P (default)
C = SDPVR TV1
D = SDPVR TV2
A = Samsung TV
This is my actual problem
But when selecting any other function on the remote it blinks 2 reds immediatly on pressing the sift key or any other keys.
What could it be??
