DSTV Questions
traceygr
Pretoria
Hi all
I just want to know if anyone can assist with the following two questions I have on DSTV.
1. DSTV iDrifta-will it work on the new Apple Air Ipad? :confused:
2. DSTV Premium subscription - We are on Premium. We have a single view decoder and a HD PVR. This is connected on extra view (PVR in TV room and single view in bedroom). Can I connect another TV to it on dual view in the bar area to watch what ever is on the TV room TV?:confused:
Hi all
1. Cannot see why the new Idrifta won't be able to work on the new ipad air as long as you use the drifta designed for connection to IPAd it should work fine, however I would just speak to the consultant when you buy it (or contact multichoice) and enquire with them.
2. yes you can connect another TV on your dual view and watch it in another room. I currently have an Explora and a HD PVR in dual view. both are situated in the lounge an connected to the TV in the lounge and then I have cables running to the bedrooms and have tv's in the main bedroom and in my son's bedroom. the decoders are controlled by TV eyes connected to the TV's.
Depending on how your setup is with your current decoders will determine how you need to setup the new Tv.
