DSTV Settings.
thedoc!
VTS
Company Rep
Earth
Hi All,
My DsTV Stopped working a few moments ago, and I would like to confirm my frequency symbol rate and LNB settings, basically everything in the setup feild to see if something hasnt changed.
Would really appreciate if someone could check theirs and make a post here.
I am in SA using the Ku band system.
Regards
/doc
Pull the Plug out the back, and the DSTv should reset itself when you plug it back in. Otherwise use the Red Button to change the setting. (There are only 3 options, not sure of the one for your area)
