DSTV: Smart LNB -> 1x Explora2 + 2x HD PVR 2P's connection for ExtraView.
1) I have an existing Working ExtraView (+1 SD Decoder) connection as showed in the 1st Image.
2) I would like to add an Explora2A to this connection, as showed in the 2nd Image.
Will I need a Heartbeat Cable from the Explora2 to the other Secondary (HD PVR P2) Decoders?
If so, how should I connect it?
A genius named Geoff.D helped me set up the existing connection about a year ago.
Can I just use a RF T-Piece as in this image?
Please note that I have 1x Explora and 2x HD PVR 2P's
On my existing Network Set-up >> Installation Type >> SetCR User Bans settings is:
Primary Decoder (HD PVR P2)
Tuner 1; 0:1210
Tuner 2; 1:1420
Secondary Decoder (HD PVR P2)
Tuner 1; 3:2040
Tuner 2; 4:1008
Best wait for that genius again :) , but afaik you can't run tripleview on the decoders you have . Has to be a combo of Exploras and/or the newer HD decoder
i just want a diagram of connection of extra view of a zappa hd decoder to the explora 2 with a smart lnb
