DSTV sound problem
killadoob
South Africa.
Ok so i bought a sahara 5.1 a while back and i only used two speakers but they had the right connection for my dstv i dunno what you call em but what can i use to replace it as it's busted and i can only see things with 3.5mm jack and not that red white cable setup?
Any suggestions?
I have a white and red cable from my decoder into the sahara sub and from there the speakers are output but now i cannot seem to find anything similar. Any idea of suggestions?
http://www.remarcablepc.co.za/index.php?route=product/product&product_id=1342
Could that work?
You want an RCA to 3.5mm convertor, and then you can use any old speakers.
Ok but my link wok without the converter?
I just need a 2.1 system here but that dvoom 5.1 looks sick, could i use it with the new decoders or would i need optical?
I dunno, go to the manufacturer's homepage and check what inputs it has:
RCA = no converter
3.5mm = converter
edit: dunno about the new decoders, since I don't know what output they have.
