DSTV TV Link Help
^^rac
Hi guys
I have a entry level decoder, with a RF out, to another room. Using TV link.
The line fro the RF out, is joined with one of those screw in connectors to the back room.
The TV link used to work for a few days, but then just went off.
I bought a new one, same thing. The signal to the back works fine, but the TV link does not get power ie no Light comes on etc.
How or where can i try to troubleshoot to try and fix it? What should i look for?
What screw on connector do you have?
