E Filing help
cr@zydude
Hi, I was doing my Mum's tax return, and accidentally clicked on the 'manually submitted' button. The form had already been filled in and saved, but I now can't e file it. When I used the request a correction method, it wouldn't let me submit, as the data was the same. Is there a way to fix this, so that I can still e file the return?
call them. there is no other way. might be waiting in a queue though considering the date. or you could manually submit? ;)
I've been on hold for a while. It will be bad, as I left it so late. Manual submissions ended a while ago.
Eish - crappy one.
I'd forgotten/procrastinated till earlier this morning and got mine done.
Well it took a good 20 minutes to get it sorted out, but I got a new form generated, and filed it. At least it's done now. Good luck to those doing it tonight.
