E220 firmware
jb007za
Hi all
My apologies if this question has been asked to death...
I'm wanting to do a firmware upgrade on my E220 to enable it to handle 7.2 Mbps. Where can I locate this? Couldn't find it on MTN's web site.
I have the Vodafone version so would preferably like to flash it with MTN firmware. If I remember correctly when last I did this, the MTN software accepted all versions of SIM cards (32k, 64k, 128k, etc) but the Vodacom software didn't.
Lastly, does anybody know if this is now compatible with Vista? The last firmware update I used could only be run off XP.
Thanks a mil!
BTw, this link (http://www.nerve.org.za/graham/e220fw_11_110_05_00_67.zip) no longer works unfortunately.
Hi all
Thanks a mil!
the 7.2 firmware upgrade is being updated... and will be available soon... the modems are vista compatible and you should try and use the links below...
http://www.mtn.co.za/?pid=327484&mid=327491
