So a board on one of my Pc`s popped so I bought the ECS Nvidia GF7100PVT-M (V1.0)
I only had an older copy of Windows XP on me, so I installed that... then I installed the drivers... then I installed service pack 2. There are no conflicts in the device manager and the sound simply wont work.
Its using this sound setup:
I think the problem has something to do with the HD audio drivers with windows or something. I dunno. I did try google a lot, and someone suggested drive install the windows HD audio codecs (I downloaded it from this link: ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe ) and then the Realtek HD codecs afterwards. That didnt work.
If I take the mic off mute I can hear myself talk into the mic.
In my control panel I have an IDT Audio Control Panel... which doesnt really help me much. It does do jack detects and control the volume and stuff.
In the sound settings under the Audio / Sound Play back settings for wave I have 3 options. The default is NVIDIA HDMI Audio Wave (this is the default)
The other two options are IDT Audio 1 and IDT Audio 2... if I try and change it to either of these devices there is no improvement.
Anyone know what could be causing this problem?
8 Channel High Definition Audio
Integrated 8-channel HD Audio CODEC delivering advanced multi-channel audio and bringing you the experience of home theater-quality sound.
