edge hanging in dbn
ash
Durban
when i try to connect to the network for emails, it hangs and doesnt go through. then it went through later in the day. that was yesterday. today i cannot connect again.(fine in the morning) now it just freezes again, says its connecting but doesnt do anything. What's up, my phone, or the network?
using a brand new 6630.
The problem is most likely related to the final live testing of 3G in Durban (see 3G thread). I have alerted our radio planners of the issue but if you PM me your phone number I'll get them to call you tomorrow and check it out.
Hi Ash - use Netmon to turn off your WCDMA antennae until the testing is over. There is a glitch with some firmware versions on the 6630 that cause all sorts of problems switching between GSM and WCDMA.
Now may be the time to get that firmware upgrade done :D
Cheers -
Thanks guys
MTNBB, if I have a problem today, I will pm you my details, otherwise I think you guys have enough to worry about with the 3G launch soon. Dont wish to distract you'll from that.
It was just a tad frustrating cos I needed to get my email urgently, but it came right fairly quickly.
BTW, Do you know which towers will be provisioned with 3G in durban from the outset?
