EDGE just won't appear..pls advise
Positively Negative
Mzanzi 4 Sho
Hi guys,
I did a search (howcome I NEVER find what I'm looking for in search :( ) and I need help to activate EDGE.
I have an old BB pearl 8100 and I recharged the BIS today. It's taking all afternoon and EDGE just won't activate.
Reset the battery too many times with no luck. Is there anything else I can check?
I also tried Menu > Settings/Options > Advanced Options > Hosting Routing Table and registered but with no luck.
I dialed *111# and the voice prompt doesn't offer much help. Should I call customer care and ask them to check all is fine from there side. I have previously used BIS with no issues and it activated after a few mins.
Sorry for posting this but I would like some advice please :o
