Edimax BR-6641 4WAN + 1LAN Load Balancing Router
Russell
Any idea what I could use for a small business to load balance/failover between a Telkom ADSL link and a Neotel radio signal?
Jwils
One of the Routerboards should be able to do that for you. There are scripts available on the mikrotik wiki for setting that up.
About Edimax br-6641
hi every body ,
this is the first topic for me , i bought Edimax br-6641 - Load Balancer- i put in it 3 wan cables each one 1 Mega , when i made download from www.winamp.com it gave me the transfer rate of one of these wans which was 120 kb/s -- i need the way to configure this router to download using internet download manager to reach th maximum Rate which should be 400 Kb/sec Minimum
Had both the BR-6624 and BR-6641. The 4 WAN router (6641) does not want to use all 4 WAN's at the same time on the same PC using a download manager. But with the 2 WAN router (6624) I could use both WAN's on the same PC using a download manager, thus doubling the download speed.
Maybe because the 6624 has different firmware/software than the 6641.
From what is described, it seems the routing in these routers is marking everything for a given destination and the routing tables are assigning it a single WAN. It's all most likely just some linux with iptables and iproute2 installed. Since connections are marked just once with iptables if you are reusing the connection it will always go out on the same route. It does sound like the firmware is a bit flakey in this regard.
But then thinking about it, if winamp is not trying to download with multiple connections but just one then ofcourse it will only go as fast as one of the connected lines. Since iptables will handle that one connection, the routing for everything on that connection will go the same way. Trying to split up the content of a single connection across multiple WAN lines each with a different IP might just be a total nightmare. For one, the server on the other side is not going to send a packet to an IP different from the requesting one.
Just curious though, but why 3x 1MBit lines when a 4Mbit will do?
