EeePc 700 2G - Wireless Upgrade
elf_lord_ZC5
Bloemfontein
Hi,
I have a EeePc model 700 2G Surf, which has a mini pci-e wireless card which supports 802.11b/g, I want to upgrade it to a card t hat supports 802.11 a/b/g/n such as the following one available from Miro, the Ubiquiti miniPCI-E 802.11 a/b/g/n, 23dBm (2.X) 23dBm (5.X), 2 U.FL Connectors UB-SR71E, but I will then require a new antenna dual band antenna for laptops, that I can put inside the case of the EeePc.
So far, my search has not turned up any locally. Would appreciate it, if some one can enlighten me in this regard.
Thanks,
