el cheapo versus decently priced router on ethernet cable
Tariqe
Not sure if this is the right forum. i am on a 50/50 mbps line, my 4k tv is connected via ethernet cable to the router, my question is will I get better speeds/throughput on the higher priced router, i.e better picture quality ?
No it shouldn't make a difference, you should already have enough bandwidth for 4K TV on your router and your internet.
