AdVerbatim
Hello All
I've been registered since the begging of the month on a "Linux Security"
course and I need to participate in online Labs via a VPN connection backto
the online labs.
The OS and client that I have to use is Linux and OpenVPN. The
connectivity pack (OpenVPN) and credentials where supplied, and confirmed
to be fully operational on the above linux installation when connected via
Telkom ADSL line. Other local participant's that use ADSL and 3G also have
no problems.
The problem now is when I connect to the eLabs via VPN and iBurst, I can
'ping' other machines inside the tunnel but any thing larger say a
Remote Desktop every thing comes to a grinding halt (time outs).
From my reading up on VPN it seems to be a classic MTU fragmentation issue
and my current understanding of VPN still leaves much to be desired.
I am aware of the MTU settings mention previously mentioned in these forums
eg. 1392 for browsing and 1364 for VPN. But the 1364 setting me thinks is for
when one has direct control/access to the VPN server, not a VPN server outside
your domain and control.
If any one can offer advice or suggestions on how I might cure this problem it
would be very much appreciated.
I also connect via UTD modem and PPPoE, and have no problems when using
it with XP or Linux. I also have clear sight to the tower and full signal strength,
and 'pinging' the 'iburstgroup' from both XP and Linux averages about 100ms.
Thx for any reply's...
the online labs.
no problems.
