I have double swing gates at the front of my property and only electricity on the one side, the existing cables to power the light on the other side are under the driveway and no longer work and the pipe they are fitted in is thin plastic that is closed up so it doesn't seem possible to replace them easily.
I was wondering if there are some kind of contacts that can be put on each side of the gate (probably near the top) that will meet when the gate is closed, to take power across the gate and then power a light and maybe a security camera on the other side, ac power ideally.
Someone who was quoting my family on an electric fence said they would use something like this, but maybe that would have just been for the electrified fence wires.
Does anyone know of something like this?
I don't really want to dig up the driveway ideally, possibly I will try the method of boring underneath with pvc pipe and water.
