Ridolfc
Can a regular porcelain light fitting that you buy from a hardware support a 250W ceramic heat emmiter and work at it's optimum level?
I have an enclosure for my pet Iguana and I have a exo terra wire lamp fitting that it supports up to 250W. This fitting is very old and is not working anymore. A replacement fitting is really expensive. A regular porcelain fitting is only R20, but it does not state the maximum wattage it supports.
Advice on this will be greatly appreciated.
