PegZ
- Sep 1, 2017
I have installed a number of combination light/ceiling fans in my home over the years. Some are the manual "pull switch" type - 1 pull switch for the light and a 3-speed pull switch for the fan. Others come with a remote for fan light control.
This week I learned that the light switch that the ceiling fan connects to should be a double pole type that switches both the live and neutral wires to the light/fan, and to get up to code I will need to replace all the light switches that the light/fans connect to. Can someone please confirm if it is a requirement to change the light switch, and if possible, explain why?
I have never seen a hint or other indication on any installation papers that fan/light combo's actually needed different light switches?
