I want to get a COC for the house but the electrician told me that the air conditioners require isolator boxes. Is this so?
I'm aware the geyser requires an isolator box.
If it is not on a plug top. (It can only be on a plug top if current draw is low enough)
Could well be the case, my 15,000btu units are on isolators.Max 12000btu.
They are both 12000 BTU air-cons that run using long wires to plugs in the garage, so they can be unplugged, but not at the unit.
I thought CoC requirements ended at the plug point...?
