Electronic Drum Kit Advice
syntax
jozi
Looking at getting an electronic kit, most likely the tdk4 (the 6 seems to no longer be???)
Anyone got any recommendations for or against it? Best places to purchase?
Only place online that I could find it:
http://musicmadness.co.za/Roland/Percussion/Roland-TD-4-Roland-TD-4.html
http://musicmadness.co.za/Roland/Electric-Drums/Roland-MDS-4-Roland-MDS-4.html
I am also considering getting myself an electronic set. From what I have read, the TD4 has replaced the td3 and td6, so sort of in between the two.
Do you have any prior experience with electronic sets? I was wondering how loud the noise is when playing. Would it for instance bother people in the flat next door?
Do you have any prior experience with electronic sets? I was wondering how loud the noise is when playing. Would it for instance bother people on the flat next door?
thanks for the links, I am going to marshall this wknd to check what they can sort out for me...
I have played on electronic sets previously but never owned one.
The noise is not too bad, its a fair amount less than say a practice pad would be. I know some ppl get the external speakers etc but i actually prefer the headphones (and so would my g/f). I like the td4 in the fact u can plug in external inputs for music/songs etc, can record and have the metronome with variable volume (changes volume depending on if you on the beat or not!!)
what i dont know is how well it works with a double bass pedal?
13.5k is not too bad for the kit but i reckon I could find it a bit cheaper....
I am actually looking out for a cheap second hand kit. I am not a very good drummer, I can play a few very basic beats but not much more. Since I live in a flat, an acoustic set is not really an option.
I just want something I can teach myself on, so the metronome is a good idea. I also like to just play along with some music for the fun, so being able to plug in an external source as a backing track is great.
there is the option of getting an acoustic kit and getting dampening pads, but i hate the feel!!!!!
The electronic kit is an expensive option, but the idea is to be able to mix it in with a normal kit when i get the chance to expand.
I have a Roland TD-3k and am super happy with it. It also works with guitar Hero which is sweet.
Tuerk music in strijfom park has 3 2nd hand kits for sale between R4000 and R9000
ROLAND TD-6 kit with TD-8 MODULE R9000
Dynacord 8 PIECE ELECTRONIC DRUM PAD KIT,AKAI midi trigger unit R5000
SIMMONS ELECTRONIC DRUM KIT [ 9 pieces plus bass pad] - R4000
www.tuerkmusic.co.za
