Empty Alarm Battery Case
x7razor
Hi I was wondering does any one maybe know if one can get this locally been looking around on the web and most results point to aliexpress with insane shipping costs.
All the other parts is no problem get local its just the case you get them in a couple of colors
Sadly I haven't been able to find these here myself. But I am curious to know if you are building your own 18650 style batteries.
ah man :(. I have made some small packs yes for simple battery backup nothing fancy :)
But I have been using the 3 and 4 cell plastic holders that don't require welding on the batteries it self (since i do not yet have a spot welder) and it makes it easy to replace a cell if needed.
But I have been using the 3 and 4 cell plastic holders that don't require welding on the batteries it self (since i do not yet have a spot welder yet) and it makes it easy to replace a cell if needed.
How do you use a BMS with these plastic holders?
Oh, so small 12v batteries, great for routers and low power things during loadshedding. Also, you can DIY a spot welder, but I personally refuse to do so, because ZZZZZZZZT.
Pretty sure that little circuit board there is a dumb BMS that you just spotweld 18650's or 20700's to
I mean with this one:
You would need to find something like this: https://www.mantech.co.za/ProductInfo.aspx?Item=72M5322
But with the same specs as you would need on the output. Or even these little sh*ts
