wolverinex
- Mar 13, 2009
hi,
i wanted to try out the ps1 emulator so i download the epsxe170 emulator and downloaded all the plugins , i copied all the plugins to to plugins folder and the bios in the bios folder BUT when i try to start the emulator it me me the following error msg :
so should i just try to download the emulator again or is there something i'm doing wrong with the plugins etc ? anyone have a easy step to step guide on installing and setting up the emulator ???
please help i'm really dying to try this emulator!
thanks in advance
oh yeah and if you guys know of any link to download the full emulator with plugins and bios already set-up please pm me as well, i think that would be the easiest solution however i can't find a all-in-one install package.
This application has failed to start because the zlib1.dll was not found. re-installing the application may fix this problem
thanks in advance
