Big Rat
- Jul 12, 2015
I'm gonna dumb this down a bit so that we all can be on the same page.
SO i take the RX8 and the Astra 200IE as my example.
2 rotor vs 2Ltr 4 cylinder.
So why does Rotaries have more power? I mean 1.3ltr makes 170 kw vs the 115kw for the 2.0.
My theory...
The normal roraty motor we know is the 13b. Twin roter, 1.3 liter.
How do we get 1.3 Liter?
Well, simply each rotor has three combustion chambers as it spins. each chamber is 650cc. Two rotors makes 1.3.
But recall that each rotor has 3 such chambers. so technically, for each rotation of a rotor it fires 3 times, making 1950cc used for the bang. times 2 rotors and we actually have 3.9ltr.
But then the design comes back into play, the crack spins three times for each revolution of a rotor, meaning for each bang the crank makes one revolution. 3.9/3, back to 1.3. Ok, so Rotary is truly a 1.3ltr per each revolution of the crank.
How does a 2.0 inline 4 compare?
Well, piston 1 fires and pushes the piston down, 180deg turn of the crank. Piston 2 fires, pushing piston one back up, and the crank does another 180, so one full revolution. Piston 3 fires and other 180 deg, Piston one comes down, sucking in airfuel mixture, Piston 2 goes up and pushed exhaust gas out. Piston 4 fires, another 180, making two full revolutions, and all 4 pistons fired.
So for all 4 pistons to play, you need two revolutions. For me that means a 2.0ltr inline4 is only a 1ltr motor for each revolution.
That makes sense that the rotary would be more powerful as it has a bigger capacity for each turn of the crank.
Off course design comes in, 3 moving parts for Rotary ( 2 rotors and one crank) vs 27 for inline 4 (4 pistons, 4 condords, 16 valves, 2 cams, one crank). Revving ability obviously, but the initial starting point has the rotary actually having a bigger capacity per revolution of the crank.
How much out of whack am i here?
My theory...
