Pitbull
Verboten
Unless your engine number changed and you need a new license disc, it wasn't replaced. They would have replaced the head if needed and just re-sleeved the cylinder, added a new piston with rings.
Yeah not a replacement. Still expensive for just cylinder head.
Labour is renew and dress shortblock which is imagine is a PC term for overhaul.
The first item clearly says cylinder assembly. Where are you looking?
Ok so they're replacing the block only and not the cylinder head.The first item "cylinder assembly" (FCM5G6011BA) is not a cylinder head, it is a short block.
I've checked with the Parts Dept at the local Ford dealership.
