Engine running while filling up…?
It would appear as if we have a couple of Darwin Award candidates here...:D
Why on EARTH would you want to leave the engine running, whilst filling up?????!!!!!!:eek:
Some people enjoy watching the fireball in their rear view mirror as they race off into the sunset :D
The reason they tell you to turn of your engine is because modern fuel pumps are submerged electric pumps that are located in the fuel tank.
These pumps generate electric sparks (not sometimes, all the time), there is arcing between the brushes and the commutator. Usually with the fuel filler cap closed, a vacuum is created so no oxygen is present. If oxygen where to reach the sparks generated by the fuel pump it would ignite and probably explode. Although fuel doesn't usually explode if you light it, a fuel tank is under pressure so the sudden change is pressure inside the fuel tank is likely to cause an explosion.
Fuel is ignited by heat, not sparks or lighter buds. So technically a cigarette could light petrol but generally it's not hot enough (I think on a REALLY hot day with low octane hot petrol it could be done). Sparks, generated either by fuel pump, spark plug, your hair or lightning are all based on the exact same principles, it's just the amount of current that differs. ESD (electrostatic discharge) from your hair or skin is just as likely to light petrol (especially gasoline vapor) as a spark plug, both just need oxygen and fuel vapor. ESD causes the air around the spark to become super heated, hence the danger.
Imo even if there is not a vacuum in the tank an explosion is unliky becuase the air/fuel mixture would not be right
Their test was flawed & largely irrelevant. A cig can't ignite a puddle of fuel, but it can ignite the vapours easily if the concentration is right.
No it can't that has been tested as well. To ignite the fumes you have to have more than a specific concentration and you need a flame or EXCESSIVE spark like those used to light blowtorches.
Saw this in Touwsrivier today, she sat there while they were filling the car, occasionally tipping her cigarette outside the window. Fair enough I was using my phone, also not allowed, but ja....
Jeez that irks me.
I mean - I know it's unlikely anything's gonna blow up - when last did you hear about a petrol station blowing up due to a smoker?
But still - the idea of smoking where people are dispensing petrol still makes me wanna smack people :twisted:.
Couple of words come to mind when i see those pics. Dumb and shyt are the two .
Jeez that irks me.
In my youth, the days of my naivete, I did smack someone and put their cigarette out on their dashboard at a filling station. I like to think I've grown as a person since then.
