Hi
I have a Jetta 2.0Tfsi and I have had a few problems with the car being serviced by VW northcliff in particulary, Had the car serviced by VW northcliff and complained of the car losing power(accelerator pedal just stopped working completely and the car is just coasting under its momentum) anyways, after having the car "fixed" by VW Northcliff they told me some BS part was replaced and the problem was fixed, turns out it wasnt, then my car developed a smoking problem, turns it out it has a freshly developed oil leak, so back to VW northcliff and they find that the Oil lid wasnt closed and oil was sprayed and leaked onto the engine causing the smoke/smell and overheating problem,
Long story short
14 Visits to VW northcliff later I have taken the car to VW Hatfield who replaced the faulty ingectors to fix the problem,
The problem I have now is the engine idles very rough, it feels worse than my Tdi does though, which VW say is normal for a 2.0Tfsi (the 147KW GTi engine) with 90 000kms on the clock,
Anyone have any theorys as to what I can have looked at?
Long story short
