Streetlight in the rain
- Nov 22, 2018
I.
That's honestly a waste of money OP.
That card released in 2008/9 I think, it's so old it's not worth it. I'll have a look online when I get a moment to assist if someone hasn't already by then
I agree with @animehero here, I'd try going for the GT 1030. It should be able to play lego games, maybe Fortnite as well if that's what they're into?Is this a good card for Lego games and Mine crafts? Mostly kids games. Or maybe recommend another card please
https://berghieonline.co.za/product/msi-9800gt-1gb/
https://pclinkshop.co.za/components/graphics-card-en/graphics-card/msi-9800gt-1gb/
No not a GT730, with that you may as well just go onboard.Gt 730 and gt 1030 is lowest you want to go.
If you have a 4th gen cpu you will have intel hd 4600 gfx. Its pretty darn fast. If newer you may have the uhd 630 card gfx. Both are decent for gaming. The 4600 kicks rubbish cards like the gt 210 and 710.
You would be better off getting 16gb of ram and a decent ssd like a samsung evo or crucial mx (wd blue good too). That will improve overall gameplay.
4gb of ram is too low. Crucial works nice. Get 16gb. I wont get less on windows 10, but 8gb would be pushing it.
U would also change the cpu. Get an i5 cpu.
Love this site.
So ram first and then cpu. 4gb is way way to low.
I only saw his post afterward.No not a GT730, with that you may as well just go onboard.
I agree that depending on the applications used, 4gb ram would be pushing it and OP would benefit for increasing this.Getting a dedicated gpu with only 4gb of ram is a no no. Windows 10 needs 16gb to function.
Its not really designed to run on less. Yet it allows you to.
Thats the biggest bottleneck at the moment.
The cpu passes calculations thru the memory to the gfx card and vice versa. A small pipe would drop your capacity and a bigger pipe would allow it to flow correctly. The ram is that pipe
The system will bottleneck with 4gb of ram.
The CPU will be Pentium G6405 with 4Gb DDr4-2666 and Kingston 480Gb SSD. I am trying to keep the cost as low as possible. I think the game that is played the most is Roblox. Lego Heros something and Mine craft a close second. Nothing else really that I know of.
I could not find an AMD APU in stock, or rather the FM2 motherboards for it. So I thought well if those games can run on my i3 integrated laptop graphics maybe the Pentium will work. If not I will add a cheap GPU. They play on a 720p Telefunken TV.
edit: haven't bought any other components yet
I do like the GT 1030. 30w of power usage and potent. If you have more powerful psu then more up.I agree that depending on the applications used, 4gb ram would be pushing it and OP would benefit for increasing this.
Discrete/dedicated GPU’s use their own VRAM, most notably my mention of getting gddr5 vs ddr4 and don’t rely as heavily on system ram. Adding more ram to an Intel igpu setup(or Amds APU's) however makes a world of difference as the igpu shares system memory, even if the igpu itself has an upper limit of what's available to use (typically a small portion of available memory dedicated to that function). Using a dedicated card on the other hand frees up the system ram that the igpu would have used so windows can chew up all 4gb xD
It comes down to what OP is willing to spend on upgrades. A RAM increase would see overall system performance increase as you multi task.CPU upgrade would be nice but it's pretty costly. Does the OP just want a nice bump in graphics fidelity or a smoother experience, and what is he willing to spend overall.
Regarding Raru, they might be cheaper but I've excluded them and Evetech from my links above because of the after sales service. You might save a few bucks on purchasing and it might never give you issues but heaven forbid you need to RMA something with them (this is off topic though)
Oh if you are interested, Steve at GN did a piece on how much of a difference gddr5 vs ddr4 affects the 1030. It's not to prove any kind of points, I just thought it's a good watch
