ET 500 gate motor
Azbubu
Kapkaupunki
Something happened and the remotes weren’t working anymore. Apparently caused by interference from someone else’s transmitter. Affected a couple of cars in the area too.
Reprogrammed the remotes but getting 5 short beeps, hear a click, followed by 1 short beep when pressing the button.
Can’t find this beep sequence in the troubleshooting section of the manual.
Did you erase the remotes first?
Power down, AC and DC
Bridge all 3 pins (a keyring works)
Power up (wait for 30 beeps or LED flashes)
Done
Then re-learn your remotes bridging the centre and edge pins
If the motor does not start, check the 25A fuse close to the edge
Suggest also re-learn the limits. Is there a beam? Is it on auto-close?
You also may have Holiday Lockout on
Erased the remote and reprogrammed it.
5 beeps
Click (relay?)
1 long beep.
There’s no beam or auto-close. Or there shouldn’t be, at least.
Should I “reset” everything?
Fixed. Think the master erase I performed previously didn’t work. Master erased again with the battery disconnected and reprogrammed all the remotes.
