Some more stuff being done at the new house.
I've run 3 ethernet cables up to the top floor, and these will be entering into one of the rooms through the ceiling and then into a wall box. I plan at least another 5 cables. There won't be conduit between celling entry and wall box.
For those that have done celling entry for multiple cables, what did you use to tidy it up and prevent dust/bug ingress into the room?
I've been looking for a grommet or cable gland that can be fitted to the ceiling board. All I found locally are desk grommets. I could use one of those, but there usually have an opening that will allow dust through. Finding a brushed one seems difficult, but I can add filter behind it.
Looking for something like this:
www.cableorganizer.com
Both will have to have filters.
Would like to see ideas of how to make a clean ceiling cable entry.
2-Pack: Hol-E-Cap Cable and Cord Hole Cover Wall Plate with Hole Saw Installation Kit for Drywall - White - Grommet Wall Plate - Amazon.com
www.amazon.com
Twist Lock Grommet for Cable Management
The Twist Lock Grommet Is A Self Securing Wire Cable Management Grommet For Commercial and Residential
