Ethernet Cable Ends
Dean01
Howzit Guys
How does one connect the ends of an ethernet cable? Details answer or link would be appreciated.
Howzit Guys
Have you got cable, connectors and a crimping tool? Also need a side cutter or wire stripper.
Lastly the pin outs ...
yep you need a crimping tool, i once did one the dodgy way with a thin flat screwdriver to push the pins in, was a b@stard!
Get a crimper. Don't waste your time other wise. It will last a life-time
Then use this order to put in wires
I got the crimping tool and cable tester and the modular plugs and I am in JHB, Randburg
oh ok cause I just sold over 250 meters of cables with no connectors on just last week and two days ago I got a big bag of cable with connectors on so if daiyaan needed some he is most welcome to come collect some.
boots are a cosmetic waste of time, if you ask me :/ in fact, they only get in the way if anything (by inhibiting the pin from properly locking/holding the jack into the socket), from my experience
