Excel Help - What is it called when ... (see .gif )
qdada
Sunninghill
I am trying to create; for a lack of correct terminology I call it a filter; where u select an item from some lookup and that item disappears from the look up next time you lookup again. I am describing it poorly so I created this .gif using camtasia to illustrate.
I basically manually deleted the records after each select and deleted those frames to create an illusion for what I am trying to create.
I hope you follow.
Not a macro - It is data validation, this option is listed on the Data Menu, further you have to select List on the Allow menu
