Excel Help
ChocolateBear
Hi Guys
Some help from the Excel bofs will be appreciated here...
Here's the Beef:
  • I basically have a folder containing about 30 csv files
  • I need these merged into a single workbook, with separate worksheets that will contain the data from the csv file. (i.e. I want a single workbook with 30 worksheets)
Can anybody help? Any ideas how to do this?
Dunno if there is an easier way, create a book and you will just have to right click each sheet 1 at a time from each book and select move to the book you have created
Yeah I was hoping to avoid that :)
I wouldn't mind doing that if it was just the one set of 30 csv's, but its a whole lot of them (like 6 or so). plus this isn't a once of procedure so I was hoping someone had some VBA code lying around :P
Thanks anyway
Thanks anyway
Hope someone does coz I also get stuck with this sometimes :)
Found this:
Answer -
use SAVEAS instead of Move.
use one of the options given with slight changes in coding to suit your needs.
Private Sub Command1_Click()
Dim pip As String, xl As excel.Application
Set xl = CreateObject("excel.Application")
xl.Workbooks.Open ("C:\my documents\fresh.xls")
xl.Worksheets("sheet1").Range("A10").Value = "Anydata2"
pip = "Gadbad"
xl.SaveWorkspace ("C:\my documents\" & pip & " .xls")
xl.Application.Quit
Set xl = Nothing
Print "over"
End Sub
OPTION 2
Dim pip As String , xl As Excel.Workbook
Set xl = GetObject("c:\my documents\fresh.xls")
pip = xl.Worksheets("sheet1").Range("A1").Value ' here the name to save is entered
' or you can use pip ="magician"
xl.SaveAs ("c:\my documents\" & pip & " .xls")
xl.Application.Quit
Set xl = Nothing
Print "over"
End Sub
Here
There is a perl module called "Spreadsheet::WriteExcel", which might help.
To write a string, a formatted string, a number and a formula to
the first worksheet in an Excel workbook called perl.xls:
use Spreadsheet::WriteExcel;
# Create a new Excel workbook
my $workbook = Spreadsheet::WriteExcel->new("perl.xls");
# Add a worksheet
$worksheet = $workbook->add_worksheet();
# Add and define a format
$format = $workbook->add_format(); # Add a format
$format->set_bold();
$format->set_color('red');
$format->set_align('center');
# Write a formatted and unformatted string.
$col = $row = 0;
$worksheet->write($row, $col, "Hi Excel!", $format);
$worksheet->write(1, $col, "Hi Excel!");
# Write a number and a formula using A1 notation
$worksheet->write('A3', 1.2345);
$worksheet->write('A4', '=SIN(PI()/4)');
Write a script to read in every csv file, and then write them out to their own worksheet.
I had a look and im quite sure it is simple, if not sorry.
>> File open
>> in the area "Files of type" drop the arrow and put in either "Text files" or "all files"
>> select the file and open, it gives you a "text import wizard" select what you want and I think you set.
No hassle no fuss... now where does that come from :confused: :p
>> File open
Apology accepted :)
Apology accepted
ok wait really? .. i was talking about the "comma delimited" not the Macintosh or the MS dos one .
just checking but ok. :o
The problem is that ChocolateBear is lazy and doesn't want to open the files seperately :D
Using the perl thing might be more work in the beginning, but if he do it right, he will only have to do once. In theory :p
That is in essence the mark of a truly lazy admin. Write scripts for everything, but only once.
Ok Ok
so this is what i came up with using some of my own code and code from the net :)
Function GetFileList(FileSpec As String) As Variant
' Returns an array of filenames that match FileSpec
' If no matching files are found, it returns False
Dim FileArray() As Variant
Dim FileCount As Integer
Dim FileName As String
On Error GoTo NoFilesFound
FileCount = 0
FileName = Dir(FileSpec)
If FileName = "" Then GoTo NoFilesFound
' Loop until no more matching files are found
Do While FileName <> ""
FileCount = FileCount + 1
ReDim Preserve FileArray(1 To FileCount)
FileArray(FileCount) = FileName
FileName = Dir()
Loop
GetFileList = FileArray
Exit Function
' Error handler
NoFilesFound:
GetFileList = False
End Function
Sub test()
Dim p As String, x As Variant
Dim wsname As String
p = "directory where .csv files are located"
x = GetFileList(p)
Select Case IsArray(x)
Case True 'files found
MsgBox UBound(x)
For i = LBound(x) To UBound(x)
Workbooks.Open FileName:= p & x(i)
wsname = Replace(x(i), ".csv", "")
Workbooks(wsname & ".csv").Worksheets(wsname).Move After:=Workbooks("Book1").Sheets(1)
Next i
Case False 'no files found
MsgBox "No matching files"
End Select
End Sub
Edit: Fixed it!! :D apparently the directory you assign has to look like this p = "C:\My Documents\" . It doesnt like it if u leave the trailing backslash out! :cool:
Oh and u can change the destination workbook to whatever u want I suppose... I just left it at "Book1" cos i'm too lazy, besides you have to go save the file afterwards anyway ;)
some feedback testing would be cool...though it seems to be working on my side... but its past 5pm and I may be imagining it!
Hahaha...well laziness pay off :) Just saved myself tons of manual, mind-numbing right-clicking!!!
At least if you try to automate it, you have to think about what you're doing!!
