Explicit FTP over TLS: Problems anyone?
badseed
Hi
As of yesterday we can no longer establish any "explicit FTP over TLS" connections with Vodacom 3G. TLS reaches a lag state and refuses to initialise. Connection drops. I have done all the troubleshooting possible between the web host and our systems - ADSL works fine with no problems.
I have contacted the Vodacom helpdesk and of course they have absolutely no idea what I'm talking about. "If you can access the internet then it's working" - This is what I'm told. Fantastic support :-)
Anyone experiencing the same problems?
Thanks in advance.
Update
Received a call from a very helpful guy at Vodacom, Allister - it's been escalated to the Cisco guys. So appears there may be a problem. Will revert with feedback.. :-)
Hi Jannie,
Yes tried that, no luck. However they have eventually fixed the problem as of today. Settings had changed on the Vodacom Firewall. All back to normal.
