Explora 2 - dish & cables
icemn
Hi all,
I recently moved into an apartment that has a dish and cabling already installed...
i want to get myself an Explora 2 (only - without the dish etc) but i'm not sure if the 2 coaxial cables that are coming from the dish will work on the Explora 2?? I'm not sure which decoder the previous owner used and just want to make sure
many thanks
You will need a Dstv Smart LNB for the explora.The explora only uses a single Satcr connection.
You can use both but will need a smart switch and you will need to check if it is a qaud lnb on the dish, downside is really you will eventually need to get a smart lnb.
thanks guys,
will i also require a smart LNB if i opt for the HD single view decoder?
many thanks
p.s i actually need to check what LNB is currently installed...
thanks guys,
many thanks
No,not for the single view decoder.Use any one of the cables.
