Extension cables for audio?
feo
Pretoria, South Africa
I just bought a set of new headphones but the cable is a bit too short. Where can I get an audio extension from? I need about a metre max.
Take your earphones with you to Hifi corp and and look at all the different connections u can use, but if its the 3.5mm jack then i would head on over to an electronics shop.
Take your earphones with you to Hifi corp and and look at all the different connections u can use, but if its the 3.5mm jack then i would head on over to an electronics shop. If you are in boksburg, then there is a Roleen electronics, which i think should be able to help you.
It's a 3.5mm jack yes. I'll be near Hifi Corp tomorrow, they should have it, right?
dude, just buy one. they're like 40 bucks or something at hificorp.
Ah noooo, I forgot about the damn extension! Flip!
Anyway I'm gonna be in the Hatfield area (at Uni) tomorrow, any audio places you can recommend?
