External Aerial for LTE router
Rizzler
Hello I am in Boesmansriviermond just outside Kenton. The Vodacom LTE signal has gone from OK to really kak.
Just a kilometer up the road it's perfect but not where I live. There are several Vodacom towers in the area along the Bushmans River. The fibre here is way overpriced and almost non-existent (R3 500pm for a 2Mbps line!)
Can anyone recomend an external aerial for my Huawei 3 Pro router that will help?
This is the one you want. Obviously it'll only work if you have 2 external antenna connections on your router.
Thamk you and
Thank you and yes I do have 2 external connections
Thamk you and
You may also need 2 of these depending on the type of connector on your router:
