External Drive not working!
Flippit
In an attempt to get data off the hard drive of a faulty laptop, I bought a 2.5" USB enclosure and connected the hard drive to it. I plugged it into my laptop (running Vista), and it says "Found New Hardware", and finds a USB Mass Storage Device, which shows up in the device manager, but the drive does not show up in "(My) Computer"!
What steps can I take to get it to show up?
First, make sure you have up to date antivirus in case a virus is causing the hassle. Next right click My computer and "Manange"
Then go to storage-disk management
Find the drive / partition(s) in the bottom right window and see if you can assign a drive letter.
The drive is marked as "29.94 GB Unallocated". I can look at its Properties, but the only other option is "New Simple Volume..." which sounds a lot like formatting?!?!
Screenshot
Vista doesn't recognise Fat32 as far as I know. Plug it into a machine running XP.
Failing that you can always download GetDataBack for Fat and see if you can get info off the drive like that.
it appears, mr watson, you have found the source of the problem.
my guess is that the hdd is shagged.
or you have managed to put a drive in a usb caddy in a very remarkable manner.
sssshhh...people will realise you are guessing
http://technet2.microsoft.com/Windo...0433-4ba1-a2f4-9338915fdb4b1033.mspx?mfr=true
"Windows Vista provides support for Windows 95, Windows 98, or Windows Me file systems, including FAT16 and FAT32 file systems"
You might have success with running a checkdisk on the drive as your PC starts up. Not a Vista fundi so cant help you with the technicalities.
Eish!
Don't think so - pins are lined up with connector properly... what "remarkable manner" would cause trouble?
Ja, I put it in an XP machine, with exactly the same results! Thought it would be a bit strange for Vista not to support FAT32! I think the drive is NTFS, anyway, since it comes out of a laptop running XP.
Maybe check the drive manufacturer's website. They often have tools that can help with broken drives.
It should be set on master
take a look here...
http://support.microsoft.com/kb/308421
Referring to taking ownership of files? If I could see the files, I'd be sorted!
http://www.ramelectronics.net/html/NST-250U2.htm
Don't format it obviously, you'll lose the data.
I have done all of those steps, up to before creating a new partition (to avoid formatting). No good :(
The drive is a Seagate, and the only tool I can find costs $129.99!
I have a utility to recover lost data - pm me if you want
PM sent
Plug it into a Linux machine. Might have more luck there or at least get a better idea of the problem (/var/log/messages or dmesg).
