External Hard Drive Problem
Nitro
A couple of weeks ago i had a problem with my WD 2.5 drive. I noticed 2 or 3 files were missing on it. Kind of scared to use it from now on. Can you guide me on how to check the health of the drive or do a software repair?
programs like hard disk sentinel can monitor your drive for faults
Files just don't go missing, unless moved, deleted or properties changed by malware.
+1 they especially dont go missing because your hard drive is faulty.. they would get corrupt but not missing.. its not a bad idea to still check on the health of the drive though.. hard disk sentinel and crystal disk info are pretty much the go to options.. i find that hard disk sentinel provides more information though..
Thanks guys for the advice will try those programs and see any results.
