Facetime calls being charged for?!
Dell fan
Banned
I made a facetime call which i have seen i was charged for R1,75:wtf: it uses your wifi thats all so why does vodacom charge for facetime calls? i thought it was free..
The Video data probably travels over the same 3G stream as the audio, so I would imagine you would be charged for it yes.
It sounds to me like you are charged for an initial voice call, thereafter the video call happens over wifi:
http://www.businessinsider.com/apple-facetime-video-calls-wont-use-your-carrier-minutes-2010-6
"The voice call ends as soon as the FaceTime call connects," Apple tells us. "The FaceTime call is over Wi-Fi so does not use carrier minutes."
You establish a FaceTime connection by dialling a telephone number, correct? So it stands to reason that you're going to get charged by the SP for that initial connection before it kicks over to wifi.
I don't believe it because you can do Facetime with a iPod and a Wi-Fi only iPad, millions of people have iPhones and one lone South African discovered that Facetime gets charged with a initial gsm call, I think not.
On those other devices you're connecting via an email address rather than directly dialling the other persons cellphone?
I just Facetimed myself from a iPod Touch using just my number, no email info.
When you set up FaceTime it sends an authorization SMS. You will certainly not be charged for any FaceTime call, no matter if you call an email address or cell number. FT is always free.
Facetime can sometimes send a sms in the background which you may be charged with.
Yip, Facetime sends an initial SMS upon registration to set it up - that's probably what it was (seeing it also cost R1.75 for the international SMS to Apple's servers)...
