@kronoSX Well, I have successfully hackintoshed two laptops so far, the one was a Lenovo Y510p, and while it worked good, the major problem is the onboard Wi-Fi. Major PITA. Never go the onboard Wi-Fi to work. Ran with both OpenCore and Clover.
The config.plist, I actually went through all the stuff, and built the config.plist, by getting all the details from running Windows, and then later in a MacOS VM, to create the installer (High Sierra), which things improved drastically since then with a Windows script that creates a installer USB.
I ran Mojave on the one, and High Sierra on the other laptop. The config.plist on my last attempt on hackintoshing, I cheated a little and used a Github repo, that was compatible with my laptop hardware. I had to fettle with EVERY kext to get something working. Shortcut keys? Major PITA. Brightness control? Eish. Eventually got it under control.
What wasn't working? Wireless. You have a Intel Wi-Fi chip? Chances are, it's not supported, yet. Best to run with a compatible wireless chip, here is the list of confirmed working Wi-Fi hardware:
https://dortania.github.io/Wireless-Buyers-Guide/unsupported.html#supported-chipsets.
I've been lucky to get USB 3.0 working, but also a headache.
Touchpad? Same problem. Had to use a external mouse to get by sometimes. There's really not right-click on the touchpad, so, you have been warned.
If you want to Hackintosh your G50-70, I'd recommend that you buy a SSD or get a extra unused SSD, because Apple's HFS disk format runs better on a SSD, and WILL WIPE everything on that disk. I tried with a HDD, but it messed it up badly.
If you REALLY want to run with MacOS, there's a few guides out there, to get MacOS running on a VM, I'd choose that over spending countless hours of doing absolutely nothing to get the real install working, with half of the stuff broken, unsupported.
Trust me, it's not worth it to start with MacOS, unless you want to start with Apple related things, such as developing iOS apps, etc.
Or the advertisement for that it "just works"? true, in a sense, but trying to get things done fast, and with Finder littering your desktop? Not for me.
Also, installing simple apps, for example, VLC.
Linux: open a terminal, type one line, and possibly typing in a password. Boom, installed. Heck, you can even install like 15 programs in one terminal command.
MacOS: Download the VLC image file from their site, double click to mount it, type in password, opening the mounted image file, drag and dropping the humongous icon into your applications folder, go through the installer, unmount the VLC installer image by drag and dropping the mounted disk to your recycle bin, and delete the image file afterwards if you want to. It's getting tedious if you need to install a few 3rd party apps this way.
Windows: Download installer, double click on installer, go through installer steps, installed. (For some, even a password is required)
Hackintoshing is only for the guys who really understands the in and outs of MacOS.
I know its cool to geek out with non-apple hardware to your friends...
I even had a lady asking me why I did it, and not buying Apple hardware, she was legit freaked out, and could not comprehend it.
She was mad at me for doing this sort of thing...
So, doing this will most likely not attract Apple fiends, with them shunning you and call you a freak, saying you sinned against the Apple gods for doing this unforgivable sin.
Sorry for this long post, I had to get a few things off my shoulders...
