Fan compatibility
11masoodt
Joburg
Hi guys,
I wanted to buy this fan from sybaritic. my question is will it fit on my AM2+ mobo because there is no mention of it in the information. i have a MSI K9A2 Platinum V2 AMD 790FX motherboard.
Yes it will... The AM2 fan socket size is the same of that for the AM2+
+1, but there seem to be two different versions though - one for Intel and one for AMD according to their website: http://www.zalman.co.kr/ENG/product/Product_Read.asp
You may have to get the CNPS9500 AMD (and not the AT version) :
http://www.sybaritic.co.za/store/product_info.php?products_id=9631
- I also see they have a support clip for the 9500 range: http://www.sybaritic.co.za/store/product_info.php?products_id=11241
Maybe chat to Sybaritic and see which is the best option?
...and that was helpful how?
John Burda got banned for that post, that's what I'm guessing.
You will see in the header of the Cooler on Sybaritic that it does in fact say AM2.
Sybaritic said:
intel LGA775 / AMD AM2/1207 ( AM2/1207 require ZM-oC1 optional clip support )
Then you buy the clip!!!
Also, if you need to contact Sybaritic, send an e-mail to [email protected] and ask for the attention of Graeme Simms, whom I believe is the owner. Very helpful guy.
thanks guys for the input, i'll be getting the black nVidia one with green LED's.
