Farrarmere / Rynfield ADSL Problems
Hype
Johannesburg
--Exchange Congestion and terrible sync speeds
--011 849
--4Mbit Sub - Only Syncing at 2.7mbit
--MWEB uncapped 4mbit
--6am - 2am
Tracing route to telkom.co.za [196.43.22.222]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.0.2
2 395 ms 335 ms 308 ms 41-132-56-1.dsl.mweb.co.za [41.132.56.1]
3 409 ms 426 ms 480 ms 197-80-96-210.jhb.mweb.co.za [197.80.96.210]
4 512 ms 458 ms 463 ms vl-92.vic-hscore-1.mweb.co.za [197.80.2.1]
5 513 ms 526 ms * tengig0-0-0-2.11.vic-p-1.mweb.co.za [197.80.5.22
5]
6 537 ms 490 ms 428 ms tengig0-0-0.vic-pr-1.mweb.co.za [197.80.4.141]
7 484 ms 502 ms 512 ms jhb.telkom-ipnet.co.za [197.80.4.117]
8 444 ms 352 ms 345 ms 196.43.25.137
9 384 ms 414 ms 488 ms 196.43.39.166
10 474 ms 526 ms 530 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
11 422 ms 417 ms 443 ms nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.30]
12 514 ms 528 ms 495 ms telkom.co.za [196.43.22.222]
Trace complete.
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (dB): 54 102
Attenuation (dB): 585 329
Output Power (dBm): 0 128
Attainable Rate (Kbps): 3192 652
Rate (Kbps): 2743 507
D (interleaver depth): 1 1
Delay (msec): 0.24 0.24
--Rynfield Exchange
--011 425
--4Mb Line Sync
--Afrihost Gold Business Uncapped
--Since around 12pm today
1 1 ms <1 ms <1 ms 192.168.1.254
2 561 ms 478 ms 408 ms 105-236-7-1-esr-lo.mtnbusiness.co.za [105.236.7.1]
3 488 ms 506 ms 560 ms ipc-recieve-jh-4a.za.mtnbusiness.net [41.181.178.41]
4 396 ms 412 ms 469 ms qux-jh-dca-2.za-b.za.mtnbusiness.net [41.181.165.115]
5 441 ms 340 ms 358 ms jh-dca-2.za--qux-b.za.mtnbusiness.net [41.181.165.114]
6 537 ms 490 ms 364 ms 41.181.139.109
7 511 ms 545 ms 543 ms rrba-ip-se-2-wan.telkom-ipnet.co.za [196.25.58.17]
8 474 ms 476 ms 544 ms 196.43.25.137
9 559 ms 555 ms 515 ms 196.43.39.162
10 472 ms 503 ms 544 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
11 478 ms 557 ms 561 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.34]
12 457 ms 525 ms 564 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
-- Rynfield Exchange
-- 011 969
-- 4mb Line Sync
-- Telkom ISP with 20GB Cap
Tracing route to www.telkom.co.za [165.143.158.8]
1 4 ms 1 ms 1 ms home.gateway [10.0.0.2]
2 11 ms 9 ms 8 ms ti-224-116-01.telkomadsl.co.za [105.224.116.1]
3 * * * Request timed out.
4 14 ms 11 ms 13 ms ti-224-0-13.telkomadsl.co.za [105.224.0.13]
5 14 ms 12 ms 13 ms 165.165.216.221
6 15 ms 14 ms 14 ms 196.43.51.78
7 * telkom-sa-tienet-gw.telkom-ipnet.co.za [196.25.54.62] reports: Destination net unreachable.
Trace complete.
4mb line, 20GB cap, Telkom ISP. In the past, the speeds were great 24/7 but for the past 2 months it has become impossible to use the net between 6pm and 11pm. This mybroadband forum page took 15min to load!
My wife works from home and gets the expected speeds throughout the day. The problem only seems to crop up at night when the "load" increases.
In the recent survey, I gave Telkom top marks in all categories. I will gladly revise this should a new survey be run.
There is considerable work being done by Telkom in the area at the moment. Have you guys not seen the dozens of Telkom trucks around lately? They're laying fiber optics around Homestead and Atlas rd N12 freeway ramp. They're also upgrading MSANS or DSLAMS or whatever they're called around Farrarmere and Rynfield.
Not sure the timeframe on completion. Last Telkom techie I spoke to didn't know. Said he was maintenance so wasn't aware of the details. Just stop and ask one of them when you see them...
I believe that you have hit the problem on the head. Telkom finished laying the fibre lines in Crystal Park 3 months ago. The problem started 2 months ago. Would be interesting to know when they "hit the switch" to switch us over onto fibre and see if this matches the timelines.
The fiber is apparently a long term thing. The switch to 10Mb is coming first and that's supposedly happening soon...
--Exchange Congestion, terrible sync speeds and terrible latencies
--011 425
--4Mbit Sub - Only Syncing at maybe 2Mb but typically 1Mb
--Afrihost capped 4Mb
--Whole day
Trace Route to telkom.co.za:
1 1 ms 1 ms <1 ms 192.168.0.1
2 94 ms 79 ms 83 ms 105-236-7-1-esr-lo.mtnbusiness.co.za [105.236.7.1]
3 65 ms 71 ms 74 ms ipc-recieve-jh-2a.za.mtnbusiness.net [41.181.178.17]
4 133 ms 135 ms 151 ms qux-jh-dca-2.za-b.za.mtnbusiness.net [41.181.165.115]
5 100 ms 95 ms 81 ms jh-dca-2.za--qux-b.za.mtnbusiness.net [41.181.165.114]
6 80 ms 83 ms 90 ms 41.181.139.109
7 101 ms 106 ms 106 ms rrba-ip-se-2-wan.telkom-ipnet.co.za [196.25.58.17]
8 79 ms 76 ms 68 ms 196.43.25.137
9 188 ms 201 ms 216 ms 196.43.39.162
10 146 ms 145 ms 139 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.43.23.6]
11 52 ms 47 ms 43 ms nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za [196.43.23.30]
12 69 ms 71 ms 72 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43.22.222]
Trace complete.
Speedtest.net results:
Current sync rate :1024
Router: Netgear bought from Telkom
MSAN has been installed in Farrarmere, but not live yet. Issue is that this congestion comes and goes, its fine for 3 weeks, then terrible for a week. Been sitting on bated breath for this upgrade since August last year, glad they are actually implementing these upgrades, just wish they would actually hurry up now as there is virtually zero activity at the trenches, MSAN's or anything in and around Farrarmere / Northmead. What concerns me is they are congesting the exchange with 2mbit and 1mbit connections with a few 4mbit's, i shudder at the thought of the congestion with a host of 10mbit connections running to that exchange... I hope they improve the backhaul sufficiently before they cut over to 10mbit.
The issue I have is that I am paying for a service I am not getting, on my 4mb line I am luck if I get 1mb d/load speeds with 450-650 ping to telkom.co.za
Telkom has know about the congestion for a loong time now, their excuses are wearing very thin, I think it is a real shame that due to the fact that there is no fixed line competition Telkom can do what they want and get away with it .... Shame on you Telkom
