Fast USB Flash Drive
greg_SA
Durbanville
Hi,
I'm wondering if anyone can advise me on a USB Flash Drive...
I am looking for about 4GB, and as fast as possible. Also, I'd like one that has a build in cap or slide action, so that I won't looks the cap :D
I have looked at the Corsair Voyager GT, and it seems perfect, except that it has a loose cap.
Anyone know of something similar with an integrated cap?
Cheers
Greg
Nothing with even close to the durability
every flashdrive I ever bought with a integrated cap is now broken, but with working flash memory.
Go for the Voyager GT. its the BEST! if you are a bit paranoid and want the ultimate protection get the Survivor GT.
greg, don't worry about those with caps, if you have a really small drill bit you can make a hole in the cap then using some thing nylon string you can make sure it can't be lost. It probably won't even void the warrantee as it's just a small hole in the plastic cap.
Cool idea :D
A part of me is thinking of getting an external 1.8" hard drive, but I still think they are a bit big.
