B Belgarath Well-Known Member Joined Oct 13, 2009 Messages 245 Reaction score 0 Apr 20, 2010 #1 Fax machine without printer to be hooked up with a seperate printer. Does one still get it? Is it advisable?
D Drake2007 Expert Member Joined Oct 23, 2008 Messages 4,521 Reaction score 87 Location jhb Apr 20, 2010 #2 56K Fax/Modem plugged into your PC, Windows Fax (depending on your OS version) can do the work.
B bekdik Honorary Master Joined Dec 5, 2004 Messages 12,860 Reaction score 20 Location I exist only in my own mind ... Apr 20, 2010 #3 You mean a dialup modem connected to a pc? Most Windows pc's have a fax option or you can obtain 3rd party software.
D deweyzeph Honorary Master Joined Apr 17, 2009 Messages 13,729 Reaction score 9,085 Location Cape Town Apr 20, 2010 #4 Why do you even want a fax machine? Get a scanner and use email.
D Drake2007 Expert Member Joined Oct 23, 2008 Messages 4,521 Reaction score 87 Location jhb Apr 20, 2010 #5 deweyzeph said: Why do you even want a fax machine? Get a scanner and use email. Click to expand... I wish fax would die, but yeah until that happens companies will use it even though it's likely the most costly form of one-way communication in this country.
