MickZA
Just completed upgrading from Fedora 19 to 20 using the fedup upgrade tool with no major problems.
After running "yum clean all" & "yum update" the first "fedup -- network 20" produced the following warnings on my system (YMMV):
... did a "yum remove" on the offending packages followed by "yum update" and "fedup -- network 20" then ran clean.
Rebooted and ran the upgrade option from grub. Total time from start to finish about 4 hours on a 8Mbps line.
Had to install Fripparies for F20 from http://intgat.tigress.co.uk/rmy/extensions/index.html to fully restore my F19 desktop but was otherwise a smooth upgrade.
Warning: I see from the Fedora forum that problems have been reported with fedup & nVidia systems so do your homework first.
Code:
WARNING: problems were encountered during transaction test:
broken dependencies
bpg-sans-modern-fonts-2.025-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-sans-medium-fonts-1.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-glaho-fonts-9.000-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-excelsior-fonts-2.025-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-algeti-fonts-2.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-courier-fonts-4.002-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-ingiri-fonts-4.000-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-elite-fonts-3.000-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-serif-fonts-1.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
gnome-shell-extension-xrandr-indicator-3.8.4-1.fc19.noarch requires gnome-shell-extension-common-3.8.4-1.fc19.noarch
bpg-courier-s-fonts-4.000-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-sans-regular-fonts-1.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-nino-medium-cond-fonts-4.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-chveulebrivi-fonts-3.002-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-nino-medium-fonts-4.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
bpg-serif-modern-fonts-2.028-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
java-1.8.0-openjdk-devel-1:1.8.0.0-0.19.b106.fc19.i686 requires java-1.8.0-openjdk-1:1.8.0.0-0.19.b106.fc19.i686
bpg-sans-fonts-1.005-9.fc17.noarch requires bpg-fonts-common-20120413-2.fc19.noarch
Continue with the upgrade at your own risk.
