Felicity Solar Batteries
Make sure you do your research as they sell batteries that included both Grade A and Grade B cells.
While I have nothing against Grade B cells, you just need to make sure you understand what you are getting.
As a general rule, those with an A in the model number (ipbA) are grade A. Those with an F is Grade B. This is mostly, but not always, the case.
If it was me, I would avoid until there is more feedback on how these perform
I have said this many times before cutting corners with these batteries will cost you in the long term.
Stick with the main batteries not "no names"
There are many brands that people swear by these days for battery/inverter tech that were unknowns not so long ago.
Hence my question if anyone can attest to some experience with them.
I suspect Grade B cells, but I'll look a bit further.
Thanks for the input.
experience once again will be limited you wanna be a guinea pig?
Hence why I asked "anyone" if they had experience. We've established twice-over that you do not.
Thank you for your input.
P.S. I do not mind being a guinea pig if I go into the experiment equipped with expectations.
Its a very expensive experiment thats all..
That thread should make up your mind.
Sounds like a ****-show! Thanks for the link
So its a year and a bit later to I figured Ill necro this thread.
Has anyone had any experience with Felicity solar now?
