Fibre Ready = Fibre connection?
skimread
Zumbabwe
Every fibre provider will install a fibre to copper modem. So any router that has a wan port will work which these days is most of them. Even adsl routers have wan ports so they could also work. Even if you get a router that can take fibre directly, you won't be able to connect your fibre there.
I only have a fiber wall termination box with what seems to be two ports (holes) right next two each other.
