RobertKza
I have an Archer D7 router, 2.4Ghz and 5Ghz connected through MWEB fibre 50/50 Mbps
All my Wifi connected devices have a speed of around 1Mbps to Zero, this has happened over the past two weeks and occurs on both 2.4Ghz and 5 Ghz. There are occasional brief bursts of high transfer rate using MyBroadband Speed Test but at those times Neither YouTube nor facebook photos load due to 'slow data' transfer speed
My PC on ethernet cable is fine
I have run a number of software based WiFi Analysing tools. The 2.4Ghz shows my signal strength around -45 dbm which is higher than other folk in the vicinity at around -70 dbm. I can run either with auto channel select or fixed but notice no difference. There are no other contenders on 5Ghz but I have the same poor performance.
I have run a new modem but not connected to the fibre to compare signal strength and volatility. This is lower signal strength and higher volatility.
Does anybody have ideas or possibly point me to a service provider who can identify and hopefully solve the issue
