PetrolGear
- Jun 4, 2018
Hey Guys,
I am trying to redo my sound system in the figo but not sure what to go with because I have a few rough scetches of the back board I want to setup but not sure what will be best,
System that I want to install contains the following:
2x 6x9" 450W on the back board,
4x 5x7" (still have to deside on watts)
2x 13" subs 1000W each,
a Cap,
Engine Fuse is 80W,
8 Gauge wire,
Eq that I want to install
1x Mono Block (Not sure what size yeat)
1x Amp (Also not sure what size yeat looking at a 3000W)
I want to install 2 new amps as well but not really sure on amp size on the moment I have a 1800W amp in on my subs and just 2 door speakers,
The setup for the amps and cap that I have I want to setup as per the diagram but not sure if it is right or if I should move my cap to the back of the board because I want it in front above my sub.
a Cap,
Engine Fuse is 80W,
8 Gauge wire,
